SS-V: 1130 Skew Plate Under Pressure
Test No. VS14 Find the maximum principle stress at the skew plate center at point E.
Definition
A skew plate (Figure 1) is subjected to uniform pressure.
The load is 0.7 KPa. The plate is simply supported at the perimeter: Uz = 0 along edges AB, BC, CD, and AD. Ux = Uy = 0 at point A and Uy = 0 at point B to prevent rigid body motion.
- Properties
 - Value
 - Modulus of Elasticity
 - 2.1e+11 Pa
 - Poisson's Ratio
 - 0.3
Results
        Figure 3.
Figure 4.
| Reference Solution* | SimSolid | % Difference | |
| Maximum Principle Stress [MPa] | 8.0200E-01 | 8.223E-01 | 2.5% |
Figure 5.
